Old 12-06-2014, 05:00 PM
vstol vstol is offline
Default -6an fuel check valve
I need a fuel check valve for my inline pump, any recommendations? Thanks
Old 12-06-2014, 08:26 PM
Bad Bowtie Bad Bowtie is offline
Seems simple with -6 made to the valve.
http://www.jegs.com/i/JEGS-Performan...ductId=1273572
BB
Old 12-06-2014, 08:36 PM
Rod P's Avatar
Rod P Rod P is offline
why do you need a check valve? just curious
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-07-2014, 07:17 AM
I'm curious as well. I've always just plumbed in a shut off valve (ball) in the fuel supply line from the tank so I can clean filters and what not without draining the tank. The little bit of fuel from the line ahead of that is caught in a small "dish" since there's always fuel spill from opening the filter or disconnecting the lines in the first place.
Old 12-07-2014, 08:26 AM
The fuel pump will not be below the fuel cell so a check valve will keep the fuel from draining back into the fuel cell, and not let the pump go dry. Did I miss something? Thanks for finding the valve.
Old 12-07-2014, 03:58 PM
Just FYI -- Fuel pumps like to have a flooded head. Personally I'd look at other install options before putting a bandaid on it.
Old 12-07-2014, 04:16 PM
Greg what a flooded head and how far below the top of the fuel cell is good enough not to worry about a check valve
