Old 03-10-2015, 07:33 PM
Forgeline Wheel Forgeline Wheel is offline
Default Edgar Arceneaux's '71 Chevy Nova on Forgeline WC3 Wheels
Edgar's pro-touring '71 Nova (built by Vince at Meanstreets Performance, in San Carlos, CA) is powered by a 425HP 402ci big block mated to a Magnum Tremec 6 speed trans. It rides on a RideTech bolt-on 4 link suspension, in the rear, with RQ Series coilovers. And the front suspension consists of aftermarket tubular upper & lower control arms, Hotchkis subframe connectors, Hotchkis sway bar, Hotchkis coil springs, RideTech shocks, RideTech Tru Turn steering system, and RideTech 2-inch drop spindles. His brakes consist of Baer Brakes 6P 6 piston calipers and 14 inch rotors at all 4 corners, Hydroboost braking system, Wilwood proportioning valve, and aluminum tandem master cylinder. Custom Mini tubs allowed him to fit some wide BFG Rival tires: 315/35ZR18 in the rear and 275/35ZR18 in the front wrapped around 18x11 and 18x10 Forgeline WC3 wheels finished with Gloss Black centers, Polished outers, and exposed hardware. See more at: http://www.forgeline.com/customer_ga...w.php?cvk=1313
Mark Schetter
Forgeline Motorsports, LLC
Dayton, Ohio
1-800-886-0093 x12
[email protected]
www.forgeline.com
Subscribe to our monthly newsletter here!
