Old 05-09-2006, 09:34 PM
tracy's Avatar
tracy tracy is offline
Default D & D Performance GM/Viper T56
Does anyone have experience with this transmission from D & D Performance?
I want a T56 built to Viper specs and I want to bolt it up to a BBC in my 69 Camaro. I currently have a Muncie 4 speed with a new clutch, pressure plate, throw out bearing, etc.. The D & D guys implementation is supposed to bolt right up to my current bell housing and use standard linkage, etc...Would I be better off changing over to a hydaulic clutch setup than sticking with the stock linkage?
Are there any other gotchas that people have seen with this situation that I should be aware of.
Here is the list of specs:
650 lb-ft Torque Capacity
1.125 x 26T GM Input Spline
30T Viper Output Spline
Close Ratio w/ Deep Overdrives(2.66/1.78/1.30/1.00/.74/.50)
Carbon Fibre Blocker Rings
Steel 3-4 Shift Fork
Precision built and blueprinted by D$D technicians
Direct bolt-up to GM Saginaw/Muncie/T10 bell housings
Direct bolt-up to McLeod 8630 series steel bell housings
Accepts stock GM clutches,linkage,T.O.B.,pilot bearing,trans. mount
7T GM Mechanical Speedo Drive or Electronic Speedo Drive
Transmissions come with a offset shifter (towards driverside)
Thanks,
-Tracy
