Old 07-22-2014, 07:18 AM
n77nxc's Avatar
n77nxc n77nxc is offline
Default 67 Camaro Brake Setup Question - Disc/Disc
My project is moving along, and I'm currently working on the brake system.
Here is my setup.
CPP Big Brake kit (Corvette 13" disc) with sealed bearing hubs
CPP Wilwood 2 piston rear disc kit
Brand new stainless steel hard lines
My question is what brake booster/master cylinder/proportioning valve setup I should use.
The car came with a similar setup to this:
The stamping on the proportioning valve is PV4 which should be disc disc.
I want to purchase a new setup. What do you guys recommend?
I'm just looking for a simple setup that will work well with the modern disc brakes.
TIA
1967 Camaro - Project "Resale Red" - Sold to 175RGR
