Old 12-16-2015, 03:16 PM
aany001's Avatar
aany001 aany001 is offline
Default Need a temp switch
Hello everyone. I'm hoping someone can help me out with locating a temp sensor switch for my rad. It has to be a 2 pin setup to trigger my relay with a 1/8 npt or a 1/4 npt thread. I can't use my heads cause they are already used up and I'm running an LS so no intake locations either. Any leads would be appreciated.
Steve
Old 12-16-2015, 05:42 PM
randy randy is offline
So you already used the driver front and passanger rear location on the head?
Old 12-16-2015, 06:18 PM
aany001's Avatar
Yes I have. The drivers side runs to the computer and pass side runs to my temp gauge. Rad rad has 2 spots that I can use but their 1/4 npt or 1/8 npt.
Tanks are too thin to drill and tap and Im not a fan of the probes.
Old 12-16-2015, 08:57 PM
tap the water pump. Why not use another probe to install it in the radiator? That or use a adapter
What brand of gauge? Full sweep?
Old 12-17-2015, 10:19 AM
aany001's Avatar
My gauges are new vintage USA. I managed to find a sensor from Derale part #16720. I hope this can help someone else.
Old 12-20-2015, 03:52 AM
mikels mikels is offline
If one runs to ECM why not have it control output to relay?
Dave
Old 12-20-2015, 07:35 AM
aany001's Avatar
Dave
Dave that's a great idea and I thought of that but I would like this fan to come on earlier than the PCM fan. So what I'm trying to do is have a fail safe to keep temps lower by having the fans come on at different temps as well as not having a large load coming on when both fans come on at the same time. I hope that makes sense.
Old 12-20-2015, 07:55 AM
What ECM? Many have two fan output drivers.
Dave
