Old 11-21-2015, 12:22 PM
flyinmedic flyinmedic is offline
Default New from Houston. 67 Chevelle SS
Hello everyone! I am putting together a 67 Chevelle SS for lots of cruising and some track time. I'm currently putting a Vintage air system in it along with UMI tubular upper/lower front and rear control arms with the rear uppers being adjustable. It's also getting Viking coilovers on all corners with the Ridetech rear coilover setup. The car is currently a 454, th400 with a 12 bolt and 3.73 gears and front disks. The next phase is to add full Bear disk setup, 35 spline axles with 9" housing ends, a trutrak or wavetrack and a Gear Vendors OD and a 4 point roll bar. I'm also doing and EFI conversion using the Holley Dominator EFI setup for better drivability. Finally it will be getting a Reher Morrison 583ci pump gas motor with a small shot for some track time. Here are some pics of the car currently just before I started to add anything. I am still trying to figure out a style of wheel for the car. I will update as I complete phases.
