Old 01-10-2016, 06:05 PM
Devil Dog's Avatar
Devil Dog Devil Dog is offline
Default 69 Camaro Upper Control Arm Bolts
What is the best way to remove the upper control arm pressed in bolts on a first gen Camaro? Gotta be a simple answer but I can't seem to find it and do not want to put a torch on that.
Thanks!
Semper Fi
Old 01-10-2016, 06:08 PM
JKnight JKnight is offline
A bigger hammer?
Old 01-19-2016, 12:50 PM
Devil Dog's Avatar
Default Pesky upper A-Arm pressed in bolts
I was able to remove them by placing a short piece of angle iron against the headers and using the air chisel wedged in between the angle iron and the bolt. They popped right out.
Administrator can close this post.
Semper Fi
Old 01-19-2016, 04:26 PM
leave it, it might help someone in the future.
Old 01-19-2016, 07:10 PM
Well, I was close. You needed a pneumatic hammer, not just a bigger one. Good creativity on the solution!
Old 01-20-2016, 02:42 PM
frojoe's Avatar
frojoe frojoe is offline
I placed a piece of tube maybe 1/2" long and around 7/8" ID I think (whatever ID tube fits over the flange head of the bolt) and used/tightened a beefy 1000lb-rated G clamp to push the bolt outboard, thru the tube placed over the bolt head.
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
