Old 01-03-2019, 07:44 AM
Boosted Falcon Boosted Falcon is offline
Default Advice and or recommendations needed
Need advice/recommendations for cleaning the undercarriage before applying a product like Eastwood Chassis undercoating. Are there any products that you all have found to work well and recommend?
Thanks and Happy New Year.
Old 01-03-2019, 11:48 AM
Turbo6inKY Turbo6inKY is offline
Soap and water and a good brush to get the big crud off, then follow with whatever surface prep the product you're applying requires.
Andrew Scott
1987 Buick Grand National
Web Log
Instagram
Youtube
The Following User Says Thank You to Turbo6inKY For This Useful Post:
Boosted Falcon (01-04-2019)
Old 01-03-2019, 07:49 PM
craig510's Avatar
craig510 craig510 is offline
Just use some rattle can paint for the bottom. Way easier to remove for future modifications.
The Following User Says Thank You to craig510 For This Useful Post:
Old 01-04-2019, 04:06 AM
gofastwclass gofastwclass is offline
This all depends on how dirty the undercarriage is.
If it's like most project cars I've worked on with years of caked grease and dirt typically start with a scraper. If we're past that stage I hose everything with a strong mix of Purple Power or Dawn dish soap and I let that soak then blast it with a pressure washer. After the pressure washer I'll do the brush boogie as mentioned by Turbo6inKY followed by a good rinse and dry with the air hose. Follow this with whatever temperature and surface prep your coating requires.
Obviously a rotisserie helps immensely with this method but I've done the whole thing on my back using wheel stands while lying on a creeper wearing a raincoat, safety glasses and a face shield.
I build my own junk...
The Following User Says Thank You to gofastwclass For This Useful Post:
Old 01-05-2019, 11:58 AM
ataves1's Avatar
ataves1 ataves1 is offline
Rent a Hotsy pressure washer, (or any hot water pressure washer) these things rock and roll. You won't have to scrub or scrape much at all.
The Following User Says Thank You to ataves1 For This Useful Post:
GregWeld (01-13-2019)
Old 01-07-2019, 07:16 AM
Thanks I will look into that.
The Following User Says Thank You to Boosted Falcon For This Useful Post:
jhrusk (01-13-2019)
