Old 09-21-2016, 06:27 AM
minendrews68 minendrews68 is offline
Default Does anyone have a '68 Camaro Z/28?
As the heading says, I am looking for someone that has a '68 Camaro Z/28 than can give me some dimensions on where to drill the holes for the Z/28 fender emblems. I have the manual, but it's really deceiving. It gives two dimensions (as 0) but they are out there in mid air. One (the vertical), is suppose to be at the face of the fire wall I read somewhere. The other (horizontal), shows to be about 6" below the bottom of the car, with no reference to it. It just says to start with these two dimensions (0) and measure from there, but where are these dimensions measured from? I would like to have the dimensions to the first hole on the "8" of the Z/28 (closest to the door) and how far up from the body line. The next dimension is the word "Camaro", that goes on the back of the fender just behind the front tire and above the body line.
Thanks for any help,
Old 09-21-2016, 07:48 AM
Tim john--- Tim john--- is offline
The "0" is an engineering point where all other dimensions start from, it is a tangent point. Look on top of the cowl above the heater box in front of the windshield. You will find a hole, this is your zero ("0") point.
Tim john---
Old 09-21-2016, 10:11 AM
That makes sense. What about the horizontal 0, it seems to be about 6" below the bottom of the rocker. I understand the first "reference" point, being a tool and die maker for years we used to put a "reference hole or ball" on the die shoe as a point of starting reference.
Thanks for the reply.
Carl
Old 09-23-2016, 04:48 AM
redfire69's Avatar
I would consider buying the templates. Good luck!
http://www.heartbeatcitycamaro.com/s...kit-Z-28-1968/
Ron
69 Camaro Redfire
Old 09-26-2016, 06:19 PM
Thanks guys, I got it..
Old 09-26-2016, 09:12 PM
F'in mine's Avatar
You might want to mark as per template then see if the repro emblem holes line up. Sometimes the repro stuff is off from the NOS parts. Measure twice drill once.
1969 Camaro SSRS
Simon
