Old 01-19-2019, 05:42 AM
Doug1's Avatar
Doug1 Doug1 is offline
Default Aeroquip Push Loc hose for EFI?
Anyone here have experience with Aeroquip Push Loc with EFI? My hydraulics shop tole me it was fine. It was rated for fuel and 250PSI.
The problem is that after 500 miles one of the hoses came loose and sprayed gas everywhere while I was driving. I found the following when I went to fix it. The two 6AN fuel rail lines run to a 8AN out Y fitting before meeting up with the filter.
So you can see where the hose split and then after I cut the hose back about 6 inches you can see what I found inside. Disconcerting to say the least?
Does anyone on here have similar experiences with their stuff? At roughly $6 a foot, I expect better.
IMG_5038 by , on Flickr
IMG_5041 by [url=https://www.flickr.com/photos/15918[/url], on Flickr
IMG_5043 by ,
Old 01-19-2019, 06:15 AM
dhutton dhutton is offline
I don’t see any kind of liner in that hose. I use Holley Vaporguard hose. Looks similar but has a liner. Fittings use a crimp ring.
SAE 100R6 is hydraulic hose. Most likely not intended for fuel.
Old 01-19-2019, 07:04 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
I though you were supposed to put those crimp bands or the aluminum retainer rings on those still?
Like this
https://www.jegs.com/i/JEGS/555/100080/10002/-1
or
Old 01-19-2019, 09:45 AM
Doug1's Avatar
Thanks guys. I'll look for some J30 hose.
Does anyone know of a push lock hose that is EFI certified?
Old 01-19-2019, 11:03 AM
Musclerodz's Avatar
I run Gates push lok on all our stuff. Never had an issue.
Mike Redpath
Musclerodz & Customz
facebook page
The Following User Says Thank You to Musclerodz For This Useful Post:
Spiffav8 (03-03-2019)
Old 01-19-2019, 11:52 AM
I've never had problems with XRP hose and fittings. I have seen issues mixing and matching hose and fittings; different manufacturers may have slightly different sizing on their fittings.
I also like their clamps for higher pressure apps, makes me feel better.
Old 01-19-2019, 03:50 PM
Doug1's Avatar
Do you use clamps or bands with the Gates hose?
Old 01-19-2019, 11:50 AM
cjsgarage cjsgarage is offline
I use Redhorse everything, but the gates stuff is easy to come by, too. And the metal crimps are mandatory insurance on the push lock stuff
I like wiring. No joke.
Old 01-19-2019, 08:49 PM
If you run hardline except for the flex for tank drop-down and from firewall to block, you'll save on serviceable pieces.
The Following User Says Thank You to cjsgarage For This Useful Post:
camcojb (01-19-2019)
Old 01-19-2019, 09:09 PM
Doug1's Avatar
from my iPhone using Tapatalk
Pretty much what I do.
1 from rear bulkhead return fitting in tank
1 from in pump in tank to fuel filter
1 from fuel filter to rear bulkhead pressure line
1 from front pressure bulkead fitting to filter
1 from filter to Y adapter to split to fuel rails
2 from Y adapter to fuel rails
2 return lines from fuel rails to regulator
1 from regulator return to return bulkhead
Untitled by by [url=https://www.flickr.com/photos/159188510@N03/],
Untitled by [url=https://www.flickr.com/photos/159188510@N03/]
