Old 04-29-2017, 12:18 PM
vstol vstol is offline
Default I give up with brake bleeding
My build is below and I will tell you its not my first build but the most frustrating. I have a Wilwood manual MC and it was bench bled before being attached. I have zero leaks which took a while. I used the mity vac to bleed the calibers but I was getting tiny air bubbles which I thought was from the connection with the hose. I went through a lot of brake fluid but still had bubbles but not the typical air in the system. I put the speed bleeders back on and bled them again. The pedal is still soft. To add salt in my wound I started the car which is on jacks and put it into second gear and stepped on the brake pedal only to watch it continue to spin. I am truly at a loss. This is the first time I have used a Manual Wilwood setup and help out there will be much appreciated. Thanks
https://lateral-g.net/forums/showthread.php4?t=44704
Old 04-29-2017, 02:32 PM
dhutton dhutton is offline
If you remove the lines on the master and plug the ports will it build pressure and give you a firm pedal?
Old 04-29-2017, 06:02 PM
yes I had the plugs in after bench bleeding the MC and when I hooked it up to the pedal I could barely move the pedal. I noticed when I was bleeding it the reservoir went down a lot faster in the front than the rear. Volume was low coming out the rears. As I was pulling the brake fluid with the Mity vac they were the same.
Old 04-29-2017, 06:48 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
maybe try bleeding it backwards. put a hose on the bleeder into fresh fluid, and install your mighty vac at the lines at the master cylinder. ive also had good luck with making a master cylinder cap, and adding a fitting to the top so i can lightly pressurize the master cylinder 15-20 psi to help push fluid threw. you can also try pluging the master cylinder ports one at a time to see if its a problem with the front, or rear.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 04-29-2017, 07:32 PM
I have had good success with a Phoenix reverse bleeder I picked up on eBay.
Old 04-30-2017, 03:39 AM
I was thinking of plugging the MC one at a time and heard a lot about the phoenix V-12 bleeder. Hate to spend $200 or the price of the MC. Maybe chuck Wilwood and go elsewhere.
Old 04-30-2017, 04:35 AM
Plugging one side at a time is a good idea. It doesn't sound like the master is the issue at this point.
Are you running stainless brake lines? They can be a b*tch to seal. Maybe try some conical seals.
Old 04-30-2017, 04:48 AM
Not SS just steel. I do have a wildwood Proportional valve inline to the rear should that be adjusted one way or the other? I am also going to shorten the rod today maybe its not coming back far enough?? also no leaks at all. Thanks
Old 04-30-2017, 06:04 AM
Prop valve should be adjusted for max rear brake. The direction you turn it is counterintuitive so look at the knob carefully. AMHIK...
Old 04-30-2017, 11:14 AM
ok after 1 1/2 hrs of bleeding the brakes the old fashion way the fronts have no air in them at all and work with very little pedal. The rears just when I think they do not have air in them I try to stop the rear wheels to stop at idle and I can stop them but it requires the pedal to the floor. Not good I rebleed them and the same thing. I think I will stop for a while and see if a shop around here has a good bleed tool and can do them. My head is flat from beating it against the wall
