Old 11-16-2021, 10:09 PM
SuperBuickGuy SuperBuickGuy is offline
Default CTS aka Britney Spears
She's white, kind of dirty, might end up a bit nuts but would you say no?
I didn't. okay, she's 2006 Cadillac CTS 6 speed with 100k miles and a rod-like knock. I have another motor - the one in the Fiat. For a myriad of reasons, I'm going with a different motor in the Fiat... and this came along.... all in, I'll have less then $1,000 in it (including registration and a new battery).
and a sunroof
she cleans up well
tonight I drove it into the shop... when I bought it, I never heard it run - back story is the guy I bought it from hadn't either when he bought it, got surprised after owning it for 4 years and finally fixing its issue, with the rod knock.... (which might simply be valves hitting the pistons)...
first, they didn't install the radiator correctly (thankfully it didn't break)
but that's indicative of the car.
So the radio doesn't work
windows don't go down
why did GM put the fuses in front of the rear seat?
codes are for injectors (not a surprise with 4 year old gas) and cam timing
needs a rack (leaking)
but overall, the interior smells smokish (not heavy, and even I, who am almost allergic to it, can handle it). no rips, kind of dirty (needs a shampooing)
outside no major damage, I have another bumper cover (came with) for the rear. Paint is in good shape.
desperately needs tires (and it's an odd 5 bolt - 115 mm, but you can use 114.3 (small Ford) with the right hub adapter)....
which leads me to.. you can swap hubs and get the Camaro bolt pattern along with better (larger) brakes.
That last bit is cool because I have the C5 Corvette front hubs that are a straight bolt on, and I have 4 piston Brembos from a SS Camaro for the rear - all I need is another hub and brake assembly.
which leads me to
This might become my taxi. I have a good friend that I'd loan this to for track days... also use it for autox practice.... and in the end shift it to someone else....
I won't V the car - GM changed almost everything under the car to put the V8 in it (new K member, different rear suspension, stronger diff).... and I already have a beast for days when I need the last, shouted word....
So it's a project but it's likely you'll see it as supporting cast in the future....
thoughts?
The Following 2 Users Say Thank You to SuperBuickGuy For This Useful Post:
camcojb (11-17-2021), WSSix (11-17-2021)
Old 11-17-2021, 06:16 PM
I say go for it. Those v6's aren't half bad motors. Make it handle and drive well and just go have fun.
SuperBuickGuy (11-18-2021)
Old 11-24-2021, 08:17 PM
and the motor
So the Fiat makes an appearance
it seems to have good compression still don't know what I'm going to put in the Fiat but I really should make it run somehow....
originally, I was going to twin turbo it for a Fiat 124.... now, I'll probably hit the easy button and LS it.
Old 11-29-2021, 09:42 PM
well, now Britney has shown all her fails...
come on Opel, how is this serviceable?
keeping the a/c system charged was a pain, trick is pull the PS pulley
it's out - these pictures are for posterity because the motor didn't need to come out - so probably not swapping stuff (which is why the pictures)
the first sign I should have listened to.... this motor mount is garbage - if they replaced the clutch, a reputable shop wouldn't put the broken part back in
hmm not clean but the clutch looks new
second sign, not all the bolts are the same (these are pressure plate bolts) also no thread lock
see the wear marks on the flywheel bolts?
okay to be fair to myself, the rack needs to be replaced - so most of the work I did was necessary (the cross member needs to be removed to get it).
HOWEVER, when the guy said 400 miles ago that the clutch was replaced, it triggered the thought that the noise could be related to that. Clearly it was, whether the bolts backed out or the dual mass clutch failed... I don't know, the outer ring (what the clutch rides on) moves independently with the flywheel - not supposed to do that - but the rattle clearly was that and since there were no shiny metal bits in the oil.... again, flywheel problem not bearing problem...
so I'll continue on - I'll pull the pan to be sure and probably use the injectors from my other motor on it then put it back together...
The Following User Says Thank You to SuperBuickGuy For This Useful Post:
camcojb (11-30-2021)
Old 11-30-2021, 09:48 PM
back to my original plan, apparently the movement is normal (have a guru I can ask)
so the new motor - plugs are original and look good
I put a bit of machine oil down each cylinder to try to minimize damage since this motor hasn't run in at least 10 years.
cleaned the cross member then removed the old rack
installed new rack
I ordered the 'wrong' steering rack, the old one had some kind of sensor in it - since this car came with or without, I'll either program the light to stay off or remove whatever it's sensing
​​​​​​​tomorrow new parts and see if I can get this ready to go in....
Old 12-01-2021, 09:58 PM
new parts
even new oil filter
with fancy plug installation tool
some assembly done
but a ways to go
