Old 08-25-2018, 05:29 PM
g356gear's Avatar
g356gear g356gear is offline
Default Big block chevy instantly shut off on me
Hi guys,
Was coming home today from a car show, driving down the street, when the car shut off instantly and coasted to a stop. I tried to re-fire the car and it touched a couple times and then nothing so I got it flat decked home. It looks like I have no spark when I pull a spark plug lead at the distributor. The car is still on stock coil and points. Any ideas on where to start? Thanks for the input.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-25-2018, 06:15 PM
Che70velle's Avatar
Pull the cap and spin the engine over with the starter, to see if the rotor is spinning. If so, are the points firing? You may need to clean them. If rotor isn’t turning, you have a timing set, or camshaft problem. Double check your electrical connections at the coil, and distributor. It’s a simple setup, there can’t but a couple of possible issues for no spark.
Personally, I’d go with a new electronic distributor and eliminate the chances of the points crapping out on you.
Thanks Dad!!
The Following User Says Thank You to Che70velle For This Useful Post:
camcojb (08-25-2018)
Old 08-25-2018, 09:41 PM
g356gear's Avatar
Thanks for the input. I was actually thinking about making the change over to electronic ignition in the spring, but never had the time. My concern was that this was an instant off type of scenario, so thought maybe a coil issue. It’s always run perfectly before this.
Old 08-26-2018, 12:19 PM
ULTM8Z's Avatar
ULTM8Z ULTM8Z is offline
yeah, instant off is most likely ignition. check the primary voltage to the coil.
Old 08-28-2018, 07:57 PM
g356gear's Avatar
So I pulled the coil, and I had upgraded it from stock several years ago to a Pertronix coil. I was told the 0.6 ohm Flamethrower 2 was the model to use with stock points. Apparently I should have been given a 1.5 ohm Flamethrower 1, and this may be the reason the coil failed.
Old 08-29-2018, 10:00 AM
69hugger's Avatar
69hugger 69hugger is offline
Since you mentioned wanting to update to electronic ignition, I thought I would point out IF you decide on a Mallory Unilite conversion or distributor, they require a the use of a ballast resistor OR a 3 ohm coil. I learned this because I recently blew out 2 Unilite modules instantly by connecting a "regular" (low impedance) coil.
MSD does not offer a 3 ohm coil, but Pertronix does, which works perfectly with my Unilite.
Just FYI.
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 08-29-2018, 07:21 PM
Che70velle's Avatar
Just FYI.
True. I have both a Unilite, and an MSD. I like the MSD better. I lost a Unilite module once as well, even with the correct resistor wired in.
Thanks Dad!!
Old 09-01-2018, 07:17 PM
g356gear's Avatar
Dropped in a new coil today and it fired right up. Problem solved!
Old 09-02-2018, 02:56 PM
Che70velle's Avatar
Good for you! Not too often a coil fails, but glad you figured it out, and it was a simple fix.
Thanks Dad!!
