Old 05-12-2019, 02:16 PM
jlwdvm jlwdvm is offline
Default DSE master cylinder uses a 37 degree flare???
The directions I have for my DSE master/booster combo say to use a 37 degree inverted flare with the 3/16" line to metric fittings provided for the master cylinder lines. I'm confuse...is this a typo and should I be using a 45 degree double flare like the rest of my lines?
Old 05-24-2019, 09:50 AM
572Camaro's Avatar
Jlwdvm,
Sorry no one has replied yet.
I don't know the answer, but recommend you call DSE tech support and question them. They are good and when it comes to brakes, I would call them for sure.
Old 05-28-2019, 05:40 AM
Did that....twice. They said the directions were right, one guy even said I could use a 37 degree single flare?!?!? I wasn't too confident in the info I received from the DSE tech line. I ended up buying a 37 double flare die set for my Eastwood flare kit and did 37 flares. No leaks.
Old 05-28-2019, 10:42 PM
65 Drop Top 65 Drop Top is offline
I think by 37* single flare, he probably meant AN fitting. A lot of guys will use AN fittings through out the brake system.
Old 05-29-2019, 06:09 AM
The whole debate that nobody seems to be able to answer is:what is the flare in the master cylinder? The kit comes with metric to 3'16" line adapters....but what is the actual flare inside the master?
Old 05-29-2019, 11:06 AM
The instructions definitely say to use a 37* inverted flare
