Old 01-09-2020, 07:18 PM
Whitepark Whitepark is offline
Default Mann Hummel advice sought
I have a 416 LS3 in my Camaro. Dart block and heads, Holley throttle body injection - 600hp. Currently the engine vents into a firewall mounted catch can (see catch can beside a/c firewall lines), with vent hoses plumbed off the back of the thick spacers which sit between the engine block and valve covers on both banks, and thus both sides of the engine feed into the vented catch can - venting to the atmosphere.
I'd like to go to a Mann Hummel closed vent system, draining back into the sump and am seeking plumbing advice.
Is the plumbing as simple as taking the existing hoses from each bank and plumbing them into the Mann Hummel Pro Vent 200 can; plus routing the Mann Hummel drain vent into the LS3 sump?
The Following User Says Thank You to Whitepark For This Useful Post:
Corey R. (01-15-2020)
