Old 09-14-2020, 12:34 PM
paulk68 paulk68 is offline
Default Sound deadening placement
Would you guys put sound deadening in the rear quarter panel area?
Old 09-14-2020, 01:03 PM
Default i didnt
and not that my windows are in proably wont.
What did you do on doors ?
Old 09-14-2020, 01:04 PM
dhutton dhutton is offline
I don’t.
paulk68 (09-14-2020)
Old 09-14-2020, 01:19 PM
slimjim's Avatar
slimjim slimjim is offline
I also haven't, but I may put some over the wheel arch inside there.
How did you like kilmat?
NC
streamline 68 camaro
Build Thread here
Old 09-14-2020, 01:50 PM
I just did the door skins and what a difference it made in how the door sounds and closes.
The Following 3 Users Say Thank You to paulk68 For This Useful Post:
camcojb (09-16-2020), dhutton (09-14-2020), WILWAXU (09-14-2020)
Old 09-14-2020, 01:51 PM
It is the first brand I have ever used so nothing to compare it to but it is easy to lay out and mad e a huge difference in the door. Plus I really liked the price
Old 09-14-2020, 03:09 PM
slimjim's Avatar
yeah ok, I've used others and also decided to recently use kilmat and I was very happy with it so far, especially the price for 80mil. I also bought the aluminum tape to seal the joins and I recommend that, for no reason other than to avoid getting black goo on everything, including my clothes as I continue to work in there
NC
Build Thread here
The Following User Says Thank You to slimjim For This Useful Post:
Old 09-16-2020, 04:58 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I did. Also covered as much of the wheel well as possible. Made a big difference even without the back half of my interior installed. Worth the effort.
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
paulk68 (09-17-2020)
Old 09-16-2020, 07:12 PM
Wheel tubs and trunk floor can make a big difference. As does a good sound barrier on the back seat trunk divider panel. Carpet on the trunk floor too.
Old 09-17-2020, 04:37 PM
F'in mine's Avatar
I ended up adding a little extra insulation around some critical areas where exhaust heat from headers, intermediate pipes and mufflers are routed as well as the back seat divider.
https://www.thermotec.com/products/s...hermo-guard-fr
I found that the extra barrier helped fill in the carpet better.
To punch around bolt holes......take a piece of thin diameter pipe 3/4"-1", grind a bevel around the tubing then hammer at areas that you need to fasten stuff to, makes a nice clean open area.
1969 Camaro SSRS
Simon
