Old 09-12-2018, 05:32 AM
calvin calvin is offline
Default 11 or 12" rear rotors?
Hi,
Doing an RS FastTrack chassis with an LSA/Magnum combo on a 66 Chevelle. I'm guessing weight will around the 3500 mark
As for brake bias would 14" front with 12" rotors be too much/little for this combo? My question is about the rears. 11" or 12" or do you suggest bigger?
Old 05-28-2020, 01:36 PM
python python is offline
12" will fill the open wheel area better.
The Following User Says Thank You to python For This Useful Post:
Spiffav8 (11-30-2020)
Old 11-15-2020, 10:50 AM
pannetron's Avatar
pannetron pannetron is offline
The Baer 13" front and 12" rear brakes on my LSA '66 Chevelle are a good match. The prop valve on my Baer Remaster m/c is set to mid range to balance front/rear braklng. IMHO the 11" rear would be too small unless you're running small diameter wheels and can't fit 12" rotors.
Old 11-16-2020, 10:57 AM
572Camaro's Avatar
12” rear rotors all the way.
For the proper appearance
Just use smaller calipers and a proportioning valve.
My two cents
Old 11-23-2020, 05:46 AM
Peter McMahon Peter McMahon is offline
I think the proportioning valve only controls when the rear wheels lock relative to the fronts, not actual braking bias.
Old 11-23-2020, 09:41 AM
dontlifttoshift's Avatar
Wut?
How could you control wheel lock without controlling bias with a passive mechanical system?
Here is what it looks like on a graph. https://wilhelmraceworks.com/blog/br...rtioning-valve
Donny
