Old 12-27-2018, 10:06 AM
SSLance's Avatar
SSLance SSLance is offline
Default New steel workbench plans
So, I'm ready to build a steel workbench for my shop. I'll post my first rendering up and ask for opinions and suggestions on what to add, subtract or change. It needs to be portable yet sturdy as I'll be using it for metal fab, vice work, grinding work and just overall bench use.
Here is where I'm at so far. Nothing has been purchased yet except the casters and locks which will be here tomorrow. Hope to find the steel locally somewhere that will cut it all to length for me to save time.
Top is 3/16" steel 30" x 60", base is all 2" x 2" square tube, and it'll have (2) fixed 4" casters, (2) swivel 4" casters with total locks and (4) 4" floor locks. (I haven't decided if i want the casters or the locks on the outboard corners so I didn't draw both in). I'll also have a shelf of some sort on the bottom braces (either expanded metal or more steel) to put the welder on, argon bottle, and other welding accessories.
The idea is to build mounts on 1.5" x 1.5" square tube that will slide into the open ends of the 2x2 tubes to hold a vice, a grinder, and whatever other tools I'll add in later.
Any thoughts or suggestions so far?
Lance
