Old 10-25-2020, 12:32 PM
Timberline's Avatar
Timberline Timberline is offline
Default LS3 sound like it’s popping popcorn
I have a new GM crate motor LS3 525 and the first time I started it the engine purred like a kitten. Two weeks later I finally get back to take the car for a test drive and it sounds like it is popping popcorn out the pass side tail pipe.
Clarification I didn’t get the car out of ten drive way. Rev it easy to 2000rpm let it go back to idle it pops several time. Slowly take the revs to 3000rpm slowly bring it back to idle it pops even when the revs are climbing.
Any ideas where to start looking?
Jeff
66 Nova Sport Coupe
Detroit Speed equipped front and rear
LS3 525hp, t-56 6spd
Build in progress
Old 10-25-2020, 04:12 PM
randy randy is offline
Any check engine light? Do you have access to a scanner? Can you view any misfires? Can you post a video?
Old 10-25-2020, 07:21 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
scan tool, check for a misfire. check make sure all your spark plug wires are on tight, none backed off. post a video if you can
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 10-25-2020, 10:23 PM
Timberline's Avatar
the check engine light did come on mid way through the run will check plug wires again.
I did have a 13 second video but it wouldn’t load.
Don’t have access to a scan tool.
Jeff
66 Nova Sport Coupe
Build in progress
Old 10-26-2020, 04:14 AM
dhutton dhutton is offline
If you are going to mess with cars like this you need to spend $50 on a scanner that can reset codes.
Old 10-26-2020, 12:12 PM
Guessing a plug wire came off. Unburnt fuel entering the chamber causing popping. Need a scan tool. Go to any parts store or Walmart and pick one up. If you were local to Dallas I would help you
