Old 06-05-2019, 02:48 PM
VTtransam VTtransam is offline
Default '69 Camaro + Speedtech Extreme + Anvil inner fenders = tire size?
Finalizing my build and trying to decide on 295 or 315 tires for the front.
Rims will be 10.5" wide with 8.25" backspacing.
Does anyone run stock outer fenders, Anvil Auto inner fenders, and a Speedtech Extreme front subframe on their '69? If so, what tires size did you go with?
Thank you,
Old 06-07-2019, 11:21 AM
Blake Foster's Avatar
Thank you,
cant comment on the Anvil inner fenders (but u think they will limit the tire to a 295 maybe a 305) and what size tire they will fit. But if you used our inner fenders with stock outer fenders and the wheel you spec'ed a 315 is no problem.
Blake Foster
www.speedtechperformance.com
The Following User Says Thank You to Blake Foster For This Useful Post:
vdrivinmike (06-07-2019)
Old 06-10-2019, 10:08 AM
ANVIL1's Avatar
ANVIL1 ANVIL1 is offline
Default Anvil Inner Fender
You can run 315s with our (Anvil) inner fenders with the right back spacing.
MaTT
ANVil Auto
__________
'69 Camaro
'73 Camaro
'10 Camaro RS/SS
'96 Viper GTS
'70 Bronco
'69 Mustang sports roof
The Following User Says Thank You to ANVIL1 For This Useful Post:
redfire69 (06-10-2019)
Old 06-10-2019, 06:58 PM
Thank you Matt. I don't have the Anvil inner fender extensions, and still have the stock outer fenders. What backspace do you typically see with your inners and 315 tire?
I'm appreciative that both vendors took the time to reply. Thank you!
Old 06-14-2019, 09:40 PM
alongfortheride alongfortheride is offline
No offense I had speedtechs inner fenders with the extreme subframe. Do not do it the inner fenders fit poorly at best. Ended up reworking stock steel inner fender wells for a nice clean look.
Old 06-19-2019, 11:19 AM
WOW we install then all the time and they look AWESOME!! they are not a "BOLT IN" they are made to fit with some modifications. here are 2 examples.
Blake Foster
The Following 3 Users Say Thank You to Blake Foster For This Useful Post:
camcojb (06-20-2019), dhutton (06-19-2019), jarhead (06-20-2019)
Old 06-25-2019, 02:14 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
If you still have those "poor fitting inners" I will take them off your hands
The Following User Says Thank You to 98ssnova For This Useful Post:
Spiffav8 (08-04-2021)
