Old 08-31-2006, 07:35 AM
CamaroGbg's Avatar
CamaroGbg CamaroGbg is offline
Default Need help!!!
What Torque Should I Use To Tighten My New Fidanza Alu-flywheel To The Crankshaft? And What Torque Should I Tighten The Centerforce Dual Friction Clutch To The Flywheel? It`s A 396 Bigblock...
Thanks In Advance....
Mikael
Old 09-12-2006, 12:27 PM
CamaroGbg's Avatar
Canīt anyone help me with this?
Someone has to know....let me know asap!!!!!!!!
Old 09-12-2006, 01:13 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Mikael
Fidanza site "Follow the OEM specifications for the torque and replacement of the flywheel to crank bolts and clutch mounting bolts."
Old 09-12-2006, 01:31 PM
fatlife's Avatar
fatlife fatlife is offline
Banned
I would put the flywheel bolts in with some blue locktite at about 80ilbs, the pressure plate bolts should be about 10ilbs or less with some blue locktite also, in a star pattern. These are just numbers off of the top of my head so feel free to correct me or double check.
Old 09-12-2006, 01:51 PM
Flywheel should be about 65 ft. lbs. and pressure plate should be about 35 ft. lbs. if they recommend stock specs.
Old 09-12-2006, 02:50 PM
Mkelcy's Avatar
If you're using new ARP bolts (I'd recommend doing so) ARP will specify a torque value, depending on whether you use oil or ARP lube on the threads.
Old 09-12-2006, 10:57 PM
CamaroGbg's Avatar
Just found the specs on the net. Flywheel 65ft.lb and pressure plate 35ft.lb
so you where right, Jody
Mikael
Old 09-12-2006, 11:05 PM
Mikael
That's amazing! What do I win???!!!
Old 09-13-2006, 09:24 AM
fatlife's Avatar
Banned
a fruit cake!
35ilbs sounds like a lot for the pressure plate, be carefull not to warp it
Old 09-13-2006, 10:09 AM
MaxHarvard's Avatar
Originally Posted by fatlife
a fruit cake!
Are you talking Inch Pounds or Foot pounds? i notice a difference in your guys wording. 35 FT lbs, sounds about right for a pressure plate.
