Old 03-18-2023, 11:14 AM
James OLC's Avatar
Default Lateral Dynamics 2.0 Subframe and Floater 9”
Item Location (City/State): Indianapolis, IN area
Price: $9,000 for all or as below
Description:
For Sale
Lateral Dynamics 2.0 Subframe (2022 build) - fits 1967 - 1969 Camaro, Firebird, Nova
Complete front subframe - new in box - never installed. Included upper and lower control arms, Lateral Dynamics modular spindles, SKF C6 hubs (active sensors), Howe racing precision ball joints, and all installation hardware. Speedway engineering 3-piece splined front sway bar - tubular sway bar, splined sway bar arms, speedway pillow block mounting bushing and all hardware. T56 transmission crossmember. Subframe is painted steel grey, control arms are black. This sub has fully adjustable geometry and is designed to be equally comfortable on the street or track. $7,000 obo
Lateral Dynamics 2.0 floater (2022 build). Ford 9” housing - new in box - never installed. Fully welded Ford 9” based housing, Millerbuilt full floater with C7 rear housing ends and SKF C6 hubs (active sensors), calliper brackets and all installation hardware. Fits 1967-1969 Camaro - narrowed about 1” vs stock, measures 57.” outside axle flange to axle flange, will require different brackets for use with leaf springs or a great start to a custom 3-link. $3,000
Subframe + Ford 9” housing together - $9,000. Both are currently crated for transportation and located in the Indianapolis, IN area.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 06-22-2023, 07:07 PM
Elliottb Elliottb is offline
James- I sent you a PM about the Subframe and Floater.
