Old 09-18-2006, 11:30 AM
superpro787 superpro787 is offline
Default 700R4 swap into 67 fbody
small block chevy an 700r4 into a 67 Firebird. Will i need to modify the tranny crossmember. Currently I have a turbo 350 trans.
Jerry
Old 09-18-2006, 04:34 PM
Found this on the web today!
http://www.bowtieoverdrives.com/cata...php?ITEMID=100
What you guy think?
Old 09-19-2006, 01:59 PM
markss28 markss28 is offline
when I installed my 700r4 in my 73 camaro it was no big deal at all. It pretty much a longer TH350. All I had to do was move the cross member back about 1 1/2" drill some holes in the frame and done. I will recomend just because to get sub frame connectors. Mainly because you just drilled some hole in it.
Never Stay Stock
