Old 11-14-2006, 05:56 AM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Default C6-Z06 Group purchase.
Edit! I got the whole deal for 1495$ from www.fbparts.com +65$ shipp.
To all looking for an awesome deal on C6-Z06 brakes....
http://forums.corvetteforum.com/show...post1557692563
I'm in!
Just tought i'd let you guy's know.
Scott, if its not ok to post links to gp's on other sites please delete.
Lead.
(Looking around a 1500 - 1600$ kinda deal i'd say. We had it at 1550$ shipped from Fred Beans but he left the dealership before doing the GP. LAPD is taking over ---No worry! Its a speed shop! Not the Police!!!)
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 11-14-2006, 07:55 AM
If you search on the C6 Z06 forum of that board you'll find that few are happy with the stock C6 Z brakes. They are upgrading to something else, especially if they track their car.
Old 11-14-2006, 08:59 AM
Leadfoot1's Avatar
Hey Jody,
I read almost everything i could find on C6 Z06 brakes and know what you mean. But for a street or light race application car its hard to beat!
I have looked around and i don't want to pay 5 grand for a brake system
(ridiculous for my use and Z06's seem to perform VERY well as long as you don't go for hard racing on a prolonged period)
That kit is great for what i entend to do with my car so i only tought i'd share.
Lead.
LEADFOOT1
Old 11-14-2006, 09:47 AM
fatlife's Avatar
fatlife fatlife is offline
Banned
I'm thinking about getting a set for my new project. I really need some bling brakes to offset the rest of the car, you think baer makes some adapter brackets for it?
but really, its cool if you know that you aren't going to demand a lot out of your brakes and like them because of the looks. At least your keeping it real
Old 11-14-2006, 10:04 AM
Leadfoot1's Avatar
OK...
Lets get this over with.
WHO OWNS A C-6 Z06 AND CAN ATTEST THAT THOSE BRAKES ARE $H!T???
Come on guy's, Speak up!
Enough of the "i heard this and this...." It comes on a 70K dollar car for x sakes!!! It has to be at least better than my four wheel drums and at least better than a stock 12" set up???????? and just try to do better for that amount$!?
GIVE IT TO ME!!! I'M LISTENING!!!
Lead.
LEADFOOT1
Old 11-14-2006, 12:30 PM
Blown353 Blown353 is offline
The stock brakes are just fine for street use and "easy" driving school/casual track use, but if you go to any track day and look inside the wheels or check the message boards most guys who track their C6-Z06's replace the brakes as one of the first things. I've seen Stoptech, Brembo, and AP on C6-Z06's at the track and all guys said they were a vast improvement over the stock brakes. One of the guys I spoke with said the 2-piece Brembo front rotors were something like 7 lbs lighter EACH than the factory rotors-- that's huge! They also said the stock brakes were fine on the street but their issues showed up on the track.
Push them hard and you run into pad taper issues, pad replacement is more expensive than "conventional" 2-pad calipers, the rotors are HEAVY (and to top if off one is vaned the wrong way.)
What are you *really* after in the car? If you want good brakes for not a lot of money go with C5/C6 standard PBR's. They are damn fine brakes and don't have the pad taper issues, pads are cheaper, etc. They just don't look as "bling" as the C6-Z06 brakes but are probably the BEST brakes in terms of price/performance out there for street cars that see occasional track days. To do much better than the C5/C6 PBR's you're now into the territory of AP, Stoptech, Brembo, and so on and are probably looking at least $2K per axle. The only real issue I've ever seen with C5/C6 PBRs is the same issue you see with any streetworthy caliper with the extra dust seals-- if you don't take a cooldown lap you'll melt the dust seals when you park the car. This isn't an issue on racing calipers because they don't have the extra external dust seals that "street" calipers have.
I have driven a C6-Z06 and found the brakes to be adequate for my "test drive" which was on the *street* which did admittedly include several very fast stops from high speed. They did not fade and the pedal felt good. I did not experience or witness any of the issues that the brakes have-- which always appear on the track during prolonged heavy use. Also, after test driving I did not ask my friend if I could put his car up on the rack, pull the wheels and mic the pad thickness. Although I would have done it if he said yes.
Not a good line of argument. Ford shipped their $150K GT's with defective control arms (14K in parts alone), undersize rear sealing areas on the crankshafts causing rear main leaks (believe it or not a speedi-sleeve was the warranty repair!) and some had improperly casted heads. Doesn't matter how much the darn thing costs, it can still be screwed up from the manufacturer either as a defect or a design flaw.
1969 Chevelle
