Old 02-11-2007, 06:21 PM
B Schein's Avatar
B Schein B Schein is offline
Default Got a little work done opinions wanted
I finally have had some time to work on my car again. I hulled it down here to North Caroline from Maryland back in August but last semester in school was so hectic I really had no time to work on it. I started building the cage and finally got some coilovers on the front. I have a big problem though I set the engine back some were around a 12 inches to clear the rack. This caused lots of problems first was foot room. The gas pedal wound up on the centerline of the steering column. So I cut my fire wall back open to get my foot room back, but know I no room to have build exhaust at lest a traditional style header. I can build a turbo style header that goes forward but I am concerned about heat under the hood. Here is my dilemma I can solve all these problems pretty easy if I move the motor up and forward but that would mean running 4-inch fiberglass cowl hood. Any way here are some pics what do you guys think about the 4-inch hood should I run it our just deal with the forward exhaust.
Brian
Old 02-11-2007, 06:59 PM
ironworks's Avatar
Why not move the engine over toward the passenger side. Almost all Gm cars since 60 something have been 1.5" to the passenger side for exhaust clearance. Just a thought
Old 02-11-2007, 07:13 PM
TravisB TravisB is offline
what about a fender well styled header???? and maybe some oval exhaust tubing???
I am not a fan of 4 in hoods personally.
Kenny Davis Hot Rods
Old 02-11-2007, 07:19 PM
Sales@Dutchboys's Avatar
I am not a fan of 4 in hoods personally.[/QUOTE]
amen.
dutchboyshotrods.com
269-823-2967
Old 02-11-2007, 07:29 PM
B Schein's Avatar
Moving the motor over is a good idea but my frame rails are only 28 inch wide inside to inside it barley fits in the center so shifting it over is not an option.
I already plan to run oval tubing under the car but I just need to figure out how to get to it. How hot does it get under the hood on cars with fender well headers?
I really don’t like the tall hood either but it was in the shop so I just put it on there to see how it looks. It would make life a lot easer but I guess that would take all the fun out of it. I really want to run my SS hood. I don’t know what to do right now I just wanted someone else’s opinion.
Brian
Old 02-11-2007, 07:34 PM
GM Muscle's Avatar
is there anyway to modify the frame rail to suit you?
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 02-11-2007, 07:44 PM
well I have seen several chevyII's with fender well headers on nice cars with base clear paint around the openeing not 1" around the headers and no blistering. Were you palnning on running fenderwells? I wouldn't think it would be an issue especially if they were cermaic coated.
Old 02-12-2007, 12:47 PM
HRBS's Avatar
HRBS HRBS is offline
Well its apparent I'm a cowl hood fan....
I guess its a good thing my clients are too
The Impala had a BBC w/ a super small 4qt pan and a low rise intake and the carb was still 1" above the hood line..... somethings you can not do. The Nova was done purely for looks.
PS..... I like the look of the cowl hood on that Camaro !
HRBS on Facebook
Old 02-12-2007, 12:59 PM
The Impala had a BBC w/ a super small 4qt pan and a low ride intake and the carb was still 1" above the hood line..... somethings you can not do. The Nova was done purely for looks.
they look great on a car with alot of dish in the rear........
269-823-2967
