Old 01-16-2007, 08:36 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default About Wilwood Brakes?
To All:
Why are the top end Brakes of Wilwood generally less expensive than the Bear, Alcon and other 4 and 6 piston Brakes w/ 13 and 14 inch two piece rotors?
Thanks,
tyoneal
Old 01-16-2007, 10:34 AM
Mr.VENGEANCE Mr.VENGEANCE is offline
so we low buck guys can afford it..
Old 01-16-2007, 12:17 PM
chicane's Avatar
chicane chicane is offline
The high end Wilwood's are not cheap by any means... considering that the STR caliper runs about $3800.00 a piece.
The cheaper stuff is what is packaged in kit form for the general populus. What you are actually "seeing" is their bottom end products.
Old 01-16-2007, 12:36 PM
tyoneal's Avatar
FWIW: I was thinking about the 6 front 4 piston rear calipers.
ty
Old 01-16-2007, 06:00 PM
TLWiltman TLWiltman is offline
ty
To add to what Chicane said. The Superlite 4 piston IS (I think) the top-of-the-line Wilwood rear caliper, pricewise. I would guess it is pretty comparable with whatever anybody else has to offer (you can only put so much brake on the rear anyway).
Where things get a bit cloudy is the 6-piston front calipers. The Superlite 6 is almost the bottom of the Wilwood 6-piston line (I think the GN6 is cheaper, but I don't know if they still offer it anymore). Above that, you have the TC caliper (~$750/piece), Integra 6R (~$1800/piece), the Prolite (~$2700/piece), and the STR (~$3800/piece). So, basically, Wilwood is using one of thier cheapest 6-piston calipers to make their kits from (not saying they're a bad caliper at all, in fact, that's what I'll be using).
The others
Baer: I don't have any tech here (I don't know their price for just the calipers)
Alcon: Imported (very expensive just for that reson)
Brembo: Imported (same here)
AP: Imported
Old 01-17-2007, 06:24 AM
Silver69Camaro Silver69Camaro is offline
They're also not of a monobloc design which reduces the price considerably.
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
