Old 03-19-2007, 11:15 AM
130fe 130fe is offline
Default MAF or Speed Density
I currently have an LT1 in my 68 with the MAF system. I am considering going to a SD system to clean it up (visually). Are there any advantages/disadvantages for doing this? I have some bolt ons (cam and headers) but not expected to do anymore with it. Any help would be appreciated.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 03-19-2007, 12:38 PM
nitrorocket's Avatar
Th biggest dissavantage to using SD on you motor would be air fuel ratio changes due to ambient temp changes. Otherwise, it might even run a touch better.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 03-19-2007, 12:56 PM
speed density with the correct tune will be as smooth as maf. There are tables for adjusting the air temp compensation in the stock computers, and most good aftermarket systems also use an air temp sensor and closed loop to keep the a/f correct.
