Old 03-28-2007, 02:57 PM
Majik16106 Majik16106 is offline
Default simple 91oct 355 builds?
Does anyone have or can link me to anyone who has done any decent 400+ hp pump gas 355 builds?
1964 Triumph Tr4a Restored Road Racer
2004 Nissan 350z Daily Fun
Project Ronin - Will be working on it til i die
Old 03-28-2007, 03:02 PM
Sales@Dutchboys's Avatar
Im building one right now....well mines going to be about 110What would you like to know? maybe I can help
dutchboyshotrods.com
269-823-2967
Old 04-11-2007, 12:06 AM
jamesg602 jamesg602 is offline
Talking
If your looking for a combo here is one, sorry i don't know any builders
http://www.ryanscarpage.50megs.com/combos10.html
Old 04-11-2007, 03:22 PM
cutlasskid cutlasskid is offline
http://airflowresearch.com/
Old 04-14-2007, 07:52 PM
markss28 markss28 is offline
looking on the link it shows that a 383 wiht 9.4:1 comp made over 500hp. Sounds very high for the kind of motor.
Never Stay Stock
Old 04-23-2007, 10:25 AM
Scotch Scotch is offline
Here's both 355 and 383 builds for 87-octane. Easy to duplicate- minimal fabrication required. Builds are identical except for stroke and piston (obviously).
http://www.compcams.com/Community/Ar...?ID=1945664039
Good quality parts and a well-researched combination makes for great power.
Honestly, there's not much vacuum at idle though. If that's not a big deal, this setup works great!
~SP~
Old 04-23-2007, 02:34 PM
chicane's Avatar
chicane chicane is offline
I did one back in '98 with a Goodwrench 350. Paying close attention to the quench, via FelPro's 1010 rubber coated gasket, a set of 195cc TFS aluminum with cnc'd chambers, a Comp Cams XE series camshaft topped off with a Performer RPM Airgap and a Holley HP series 750... it netted 438hp on 87.
Then... CHP did a very similar build in Feburary 2001. 411hp on 87... with ease. With pretty much the same parts. Hummmmm Now if I could find a link to the actual article....
This is part of the series that stemmed from the Feb 2001 build. It was a cheaper build with different parts yet still netted 390/425. Change a part or three... and you could have 425+ hp and still keep it on the cheap.
