Old 04-17-2007, 08:58 AM
rlplive rlplive is offline
Default 327 engine upgrades
Hey guys how's it going? I have a 69 camaro with a 327. This is what I know about the engine, it is bored .60 over, it has upgraded heads with z28 springs, I am not sure exactly what has been done to the heads. It has an edelbrock intake and a holley carb. It also has an hei distributor. I would like to switch out the carb and intake with something that will make this thing run pretty good.
It is going to have a t56 tranny and a moser 12 bolt with 373's. Any help will be appreciated. here are the cam specs
Operating Range: 1500-5500 RPM
Duration Advertised: 268° Intake / 268° Exhaust
Duration @ .050'' Lift: 218° Intake / 218° Exhaust
Valve Lift w/1.5 Rockers: .454'' Intake / .454'' Exhaust
Lobe Separation Angle: 110°
thanks Ryan
1969 Camaro. Peeling paint, rust, the whole works.
Old 04-17-2007, 10:53 AM
elctron02's Avatar
elctron02 elctron02 is offline
hey ryan.... i have a 327 in a 74 nova. urs looks pretty nice... I just posted a thread on my 72 vette... which is a few threads below ur.
the title is ( heads cam on LT1) check it out
Old 05-08-2007, 11:21 AM
pdq67 pdq67 is offline
Thumbs up
If you are spec'd about like an old hopped up 300hp/327 then you will love that cam!! (Headers and a 600 cfm 4-barrel on a good high-rise is all)...
B'c it will like an about 10 to 1 CR!!
Sucker should run like a "scalded-dog" imho!!!!!!!!!!!!
pdq67
