View Poll Results: Manuel or Auto
4L80E with shrifter 106 39.26%
T-56 164 60.74%
Voters: 270. You may not vote on this poll
Old 11-13-2007, 10:23 PM
COYBILT's Avatar
COYBILT COYBILT is offline
If it were a turbo car I would say auto, but manual it is if N/A.
1965 GTO convertible
2009 GM Design Award winner
Triple black with Subtle yet massive Modifications.
Old 11-14-2007, 01:38 PM
customcam's Avatar
Default ?
What if u have a 750 hp big block up front ?
Old 12-25-2007, 08:48 PM
6D9 6D9 is offline
Steve...with your new style "protouring" converters how does exceleration feel from a dead stop as compared to a regular street/strip converter?? Does it flash up at all??? If you did like to go to the strip at all does it make it hard to get into the cams powerband??
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 12-26-2007, 05:18 AM
Steve Chryssos's Avatar
All converters are built to spec, so if one were to demand a looser converter, I wouldn't refuse. But as a rule of thumb, converter stall runs about 500 rpm lower than your typical street/strip converter. Coupling efficiency is greater across the board as well, so flash stall rpm tends to run lower as well. Your drivetrain will tug harder on the engine.
All this should theoretically hinder E.T. and 60 foot times, but given te traction limitations of the typical pro-touring tire, the tighter converter can help overall.
A more specific response would require a detailed conversation with you regarding vehicle specs. Feel free to give us a call.
/Steve
________________
Steve Chryssos
Ridetech.com
Old 12-26-2007, 08:59 AM
6D9 6D9 is offline
Thanks for the info Steve....yeah when I go to the track I put on big n littles so im sure it would slow the car down. But im sure it would drive a whole bunch better with the tighter converter. If I could just stay away from the damn dragstrip it would be an easy choice!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 12-28-2007, 06:20 AM
SDMAN SDMAN is offline
Im doing both. The motor in my current project is using both front and rear motor plates to mount it into the A/M frame. I will swap between the 4L80E and T-56, and with the motor supported on both ends, tranny swaps get real easy under the lift. Im betting I could do it in a couple of hours by myself.
I want the T-56 because its a ton of fun to manually shift a hi HP car (Procharged 542ci pump gas combo....approx 900 HP). But, I will also be making some serious 1/4 mile passes, and want the increased performance and consistency that the auto will have. Frame goes into the race car shop on Jan 3 for the 4-link and watts setup install. The minitub on the body is also underway to make room for the rear tires (the rear seat is going to be pretty narrow).
Question for someone who knows the answer to this. We have to cut the floor out of the car to get it onto the A/M frame. Then, with the drivetrain installed, put a floor back in leaving the required clearance in the tunnel. We would like to use the larger (physically) of the 2 tranny setups to do this. One will be the 4L85E and the other will be the T-56 on a McLeod modular bellhousing.
Which setup is the larger one?
Old 04-03-2008, 05:17 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Gotta say 4l80E, I'm old and my knees are older!
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 04-11-2008, 06:17 AM
deuce_454's Avatar
Default OLD thread
how old is this... it was posted on 09-04-2005, 10:38 PM please some moderator lock this or add "old thread" in the title... i mean if the guy hasnt chosen a tranny yet, he propably never will
Jake: Hit it.
Old 05-27-2008, 11:32 PM
jonny51 jonny51 is offline
I chose a T56 a long time ago.
Old 06-04-2008, 08:46 PM
Silver69LS1's Avatar
Silver69LS1 Silver69LS1 is offline
Originally Posted by jonny51 View Post
Okay I need some opinions.Should I run a T-56 or a 4L80E with a shrifter in my camaro.It will have a SBC TT, Hp will be about 800+.I am having a real hard time deciding on which one to run.
I'm going with a built 4L80E and the Shrifter. Easy choice with all that power. Once you get over the 750hp mark, The baddest T-56 will not hold up for long. I guess it depends on how hard you are planning on driving it. I was torn myself, until I found that Shrifter. Mine's still not together but I can't wait to try it.
1969 Camaro
Twin Turbo LSX project in progress
