Old 07-08-2007, 01:26 PM
marxcamaro marxcamaro is offline
Default Frame Measurements Issues
I am installing a Art Morrison Tri-4 bar system along with there crossmember and frame rails into my '70 Camaro. I am having issues with getting level measurement points to measure from to properly locate the crossmember and frame rails. Does anyone have blueprints or know of a company that offes a body/frame dolly or jig that I could use to solve my measurement issues? Thank you in advance for any help!
Old 07-09-2007, 05:12 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Marc, GM has a chassis manual that gives almost every dimension for your car.
67 RS/SS
Old 07-09-2007, 10:33 PM
Default 70 camaro frame
you can get a frame chart from ebay....http://cgi.ebay.com/ebaymotors/FRAME...spagenameZWDVW
Old 07-11-2007, 05:00 PM
TBART70 TBART70 is offline
like to see how you proceed with the install, did mine 3 years ago. Would have done it little differently now.
Old 07-12-2007, 07:39 AM
Thanks for the pics. How did you intstall the frame rails squarly inside the body? I am having difficulties becasue the pinch welds and other points on the car are not square. What kind of measurement instruments did you use?
Old 07-12-2007, 09:42 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
PM me your email address and I'll email you a copy of the frame charts when I get home.
Old 07-12-2007, 04:44 PM
I did this 3 years ago I'm trying to remember. I used a tape measure, make sure you have some reference points, either factory or your own. I made sure the car was dead level, did you buy a welded clip or did you get a kit? I had the clip witch made it a lot easier. I didn't use the rear most 2x4 cross member, I used a 2" x .120 wall tube, it fit better in the rear of the car. The two mistakes I made (among many on other parts of the car) were i didn't support the rear of the car enough when I cut it apart, and when I trimmed the front cross member I made it a little too wide and beat the chassis in, it didn't go in that hard but it did push out the rockers a hair, issues to be dealt with when the body gets finished. I welded plate on the inside of the rockers where the cross member fit up, the rear I cut into the rear panel for access, I put on a new one afterwards anyways, and tied it in to the inner panel. I found some reference points inside and under the car, measured off of them and made a straight line across the floor, that is where the cross member welded to the factory floor. I know this doesn't give you exact points, but I should have tried to find them like you are. The welded chassis is already square, so I made sure it was the same distance from quarter panel edge, rockers, any supports that were there, although most cars are not perfect from side to side unfortunately. I took the centerline of the chassis and the centerline of the car as a reference. For reference to height I measured to the under side of the package tray and trunk. I did have the car level so I made the chassis level front to back and side to side. Square is hard to measure, I checked wheel base side to side. I did make reference points from the old rear end axle centerline to the car, and used them when I put in the new one. I would probably go about it a little different second time around.
