Old 05-17-2005, 02:08 PM
T Bell T Bell is offline
Default Best sand for sandblasting
I have a contractor friend that will give me sand. He has the white fine sand and the coarser tan sand. I know I have to have a mask on so the silica does squeeze the life out of my lungs. Which is better for blasting a frame and rear axle with light rust?
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 05-17-2005, 02:22 PM
907rs's Avatar
907rs 907rs is offline
Either one will work great given you have the correct size nozzle.
Although it's nice to save money by getting the sand for free, I'd highly suggest you look into some of the more health friendly blasting media out there. They don't cost a lot considering your life is at stake, and you wouldn't believe how fine the dust generated by using sand can be.
Good luck!
Bill
Old 05-17-2005, 02:49 PM
So it's even dangerous with one of those charcoal painter's mask?
Old 05-17-2005, 04:15 PM
907rs's Avatar
I wouldn't say that without knowing for sure, but it wouldn't hurt to check out the MSDS sheet if one is availiable, or at least checking with a local supplier for the appropriate personal protective equipment.
Bill
Old 05-17-2005, 07:38 PM
Fluid Power's Avatar
Default sand blasting
If you check any filter, it will say it is not approved for "sand blasting" i.e, silica dust. The only "approved" method to be used with sand is a fresh air system. It is a bit spendy for the weekend warrior. In fact, here in Ohio, I was told that sand was not for sale as blasting media anymore due to liability reasons. We use Black Beauty (trade name) for blasting and it is coal slag. It produces little dust and can be purchased in several sizes depending on the desired courseness. We still use a fresh air system and other methods to control dust.
My recommendation is do it safely or don't do it at all. It is also very inexpensive to have things sandblasted professionally. Just my .02.
Darren
Old 05-17-2005, 07:49 PM
68protouring454's Avatar
Default blast
i use recycled glass, called glass jet, much safer than all this silica crap, check local auto body supply shop
jake
