Old 08-05-2007, 08:27 PM
Mr.VENGEANCE Mr.VENGEANCE is offline
Default Anyone in here running an Art Morrison AME front clip? on a 67-68 Camaro
Im looking into getting one and got a couple of ?s for those who have that setup..
Whats the widest front tire it can accept?
if by chance you know someone running 18s of 19s up front in thier widest id like to run the proper backspacing. and i can probably change my order if i knew what it was..
I already hit up Craig but i wanted to know from someone with the clip.. especially if you have a 67 68 Camaro..
thanks for the help guys..
Old 08-06-2007, 08:57 AM
hmmm.. noone huh?
Old 08-06-2007, 09:13 AM
kennyd's Avatar
kennyd kennyd is offline
we have one in a 69 , will that help
Old 08-06-2007, 09:43 PM
cluxford cluxford is offline
Mine is on a boat to Australia, will go in a 68 Camaro.....will be here early Sept and in by end Sept.....
68 Camaro 632 BBC 800+ HP Project (600Kw)
61 Buick Lesabre Bubbletop (daily driver)......miles of smiles
Old 08-06-2007, 11:10 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Been following the thread, would you mind giving the information on your car? (Tire and wheel width w/ BS) Do they rub at all? How does your car perform?
Do you drive it hard as to explore the complete performance limits? Did you start with a stock sub-frame? If so, how was it prepped prior to the install of this sub-frame? What differences can you tell between the two?
Things like this.
Thanks,
Ty
Old 08-07-2007, 03:56 AM
Steve Chryssos's Avatar
You guys might want to bug Jason at G-Force Design Concepts for answers. He's got an AME clip under the Twist SEMA car. It's another 69, but the car is pretty far along. He's probably done with all of his measuring by now.
http://www.gforcedesignconcepts.com
________________
Steve Chryssos
Ridetech.com
Old 08-14-2007, 10:15 AM
TravisB TravisB is offline
Things like this.
Thanks,
Ty
ours does not run yet.......and will not be driven hard until next spring it has to stay pretty for awhile
Kenny Davis Hot Rods
