Old 08-20-2007, 09:16 PM
Blown353 Blown353 is offline
Default Wiring Q: Accel Dual Sync to FAST XFI
I need a quick sanity check on hooking up an Accel Dual Sync distributor to a FAST XFI box. I would be running the new FAST distributors but Hogan's already made an intake (3 actually) using an Accel piece and a FAST distributor is about 1/2" taller than the Accel and will not clear the throttle body. These are Fords by the way, hence the intake to distributor interference issues.
I have another FAST dual sync distributor for reference, it requires a +12V input, a ground hookup for the wire shielding, and then the plug has 3 wires: 1 for cam signal, 1 for crank signal, and 1 for signal ground
The XFI Cam Hall plug has the following connections:
Yellow/black stripe goes to cam signal
Brown/white stripe goes to crank signal
Black/white stripe is signal ground
The Accel distrubitor has 2 3-pin weatherpacks coming out, each with red, white, and black wires, plus a shielding ground for each signal wire.
Looking at the circuit board inside the Accel I'm fairly sure that each red wire gets a +12V input, the black wire from each weatherpack needs to be tied to the black/white ground wire on the XFI harness, then the red wires for each plug are the respective signal wires (cam & crank.)
Am I correct here? I don't want to fry anything.
1969 Chevelle
Old 08-20-2007, 10:38 PM
race-rodz race-rodz is offline
red and red?
yes, you have a 12v input, then the respective cam/crank signals out. the lil led lights up when its in sync, then the rotor is "phazable" with 2 torx head screws...make sure they are tight
edit: i dont remember the colors for the input wires, but i assume the actual question was if its a 12v input signal.... and the answer to that is yes. hall effect needs input voltage.
