Modo "adapt-o-plate
We have had a few customers that have asked if our pedal covers are adaptable with the Lokar gas pedal assembly (for cable operated throttles). The answer is yes, you now can have the best of both worlds.
We have produced an adapter that will now allow you to keep your cable operated Lokar gas pedal assembly and run our pedal covers also. Our new adapter plate mounts to the existing Lokar assy and uses their hardware to mount up. just remove the Lokar gas pedal and replace it with ours. The new gas pedal looks just like our other Heel/Toe gas pedal except it is thicker. So if you have an auto or stick we have you covered.
The picture below is the front view and the back view of our new Modo to Lokar gas pedal.
The price for a set with this new gas pedal is an additional $35.00.
Thanks.
