Old 10-02-2007, 12:25 PM
GM Muscle's Avatar
Default extras i got layin around..
need a little room
gm 993 heads, factory castings, virgins! need rebuilding $75
gm 882 heads, factory castings, arp screw in studs, 202/160 valves ferrea undercut valves, machined spring pockets, new guides, these heads were rebuilt less than 500 miles ago.. the motor had some blow by and there is a small amount of gunk on top of the intake valves.. not really a big deal just making sure im as accruate as possible.. comes with springs, locks and retainers. $175
gm serpentine setup- mounts the acc right in front of the head not above, brand new alternator and powersteering pump and used ac compressor included comes with everything thing but the waterpump pulley (i used an electric waterpump) $175
passenger 1/4 panel for 93-2002 camaro, brand new, few dents from laying around $50
various reciever hitches for something.. looks to be a small suv, i have about 10 of them.. $10 each.. i can take measurents if needed..
one set of taylor spark plug wires, hei style cap and 120 degree boots, black in color built to go over a tall sbc valve cover never been ran only installed $50
1968 chevy pu 12bolt, 6 lug, w/ drum brakes $50
airlift 1000 air bag kit, they mount in side the coil spring, add air to stiffen the spring rate, brand new in the box $20
weiand intake
Action +Plus Intake Manifold
1957-86 262-400ci
1987-Up with aluminum heads
Universal Carb Flange
Idle-6000 RPM Range
$50
remanufactored quadrajet carb sbc calibration
$75
factory springs struts, and shocks from a 94 formula firebird front and rear 40k miles, $40
powder coat black lt1 centerbolt vavle covers with k&n breather $40
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 10-11-2007, 07:43 PM
GM Muscle's Avatar
updated
Old 10-13-2007, 07:33 AM
GM Muscle's Avatar
dont know why it didnt update before but it is re-updated
Old 10-13-2007, 09:45 AM
deuce_454's Avatar
the serpentine setup is for LSx, SBC or BBC?
Jake: Hit it.
Old 10-13-2007, 10:32 AM
GM Muscle's Avatar
sbc.. i believe it came off a 92 camaro. here it is installed on my chevelle
Old 10-14-2007, 06:18 AM
kleptopigdog kleptopigdog is offline
Default serp. set up
intersested in serpentine set up what all is included
