Old 10-05-2007, 09:29 AM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
Default My El Camino Finally Back On The Ground!
Hey guys, thought I would post an update on my car. I am damn near finished with a "Pro-Touring" conversion on my El Camino. I converted the drums to Wilwood discs (6 piston front/4 piston rear), added a narrowed Moser 9" with Tru-Trac and 3:70 gears, Global West trailing arms, QA1 coil overs/shocks, and Forgeline VR3P's. For all of the big ticket items, I want say thank you to Frank and Lisa Sarafin at Prodigy Customs/GP Superstore for all of their help, probably wouldn't have happened without you guys!
Old 10-05-2007, 09:37 AM
DHARROD's Avatar
DHARROD DHARROD is offline
nice ride .. looks sharp. Did you go with manual brakes, booster, or hydroboost? I got the same/similar brake set up from GP Superstore .. just a ways of from putting body back on frame. Curious on what you did and how it performs. I know at some point I have to figure out the lines hook up etc.
Old 10-05-2007, 09:43 AM
I am using the factory brake booster w/ a Wilwood MC. To be honest with you, the car has made it as far as the end of the driveway so I have not been able to see how they perform. I plan on getting a few miles on it this weekend to bed the pads and brake in the ring/pinion gears.
Old 10-05-2007, 10:02 AM
Tom.A's Avatar
Tom.A Tom.A is offline
That looks awsome
I know you had said before that you used 3" drop coils in rear, but what did you do on front?
Tom
Old 10-05-2007, 10:05 AM
Originally Posted by tom_a
That looks awsome
I used 3" drop springs in the rear, however, I think I need to go to 2" drop springs (which was suggested in the first place). The front has stock a-arms, and QA-1 adjustable coil overs.
Old 10-05-2007, 11:29 AM
Sales@Dutchboys's Avatar
WOW!
Best EL Camino ive seen...for sure
Paul
dutchboyshotrods.com
269-823-2967
Old 10-07-2007, 07:54 PM
Well I got a few miles on the car this weekend, and I am definitely pleased with the performance of the Wilwoods with the factory brake booster and Wilwood MC. Not only do they look good, but they stop!
