Old 10-24-2007, 03:34 PM
68GCamaro 68GCamaro is offline
Default DSE Mini tub kit questions for 68 camaro
Ive just got a few quick questions about the DSE mini tub kit.
1. Is it necessary to narrow the rearend to get the full backspacing allowed by the kit? If it does, how much does it need to be narrowed on with a 68 camaro 12 bolt?
2. Does the gas tank absolutely need to be narrowed? I'm on a really tight budget, so anything I absolutely don't need would help. If the gas tank needs to be narrowed what are the dimensions on it? Again it would be a 67-69 Gas tank.
I may have forgot a few questions, but I'll ask them at a later time if I remember them.
Thanks for your time and help!
Old 10-24-2007, 03:47 PM
ArisESQ ArisESQ is offline
The rear end does not HAVE to be narrowed. Most people narrow the rear so that they can get a little extra lip on their wheels.
Unless you plan on doing the Quadralink, The G-bar setup, or something else that eliminates your leafsprings and stock shock mount locations, you will need a narrowed gas tank. The minitub kit requires leaf springs to be relocated inward a couple inches, and the stock gas tank gets in the way.
The minitubs are a lot of work, so if I were you I would consider calling a few fab shops in your area, and maybe even DSE to see what they normally charge for the work. The cost of good labor will probably outweigh the cost of parts.
Good luck with it, and take your time! Do it all right the first time!
Old 10-24-2007, 03:58 PM
about how much extra lip, i would like to have wheels with quite a bit of lip on them, about how much could i do without narrowing the rear?
Thanks for the help, though, good to know i dont have to cut the rear end
Old 10-24-2007, 04:17 PM
my rear end was not narrowed and I think I have a decent amount of lip on the rear wheels.
those wheels actually fit on my car before it was minitubbed, so they arent nearly as wide as they potentially could be.
Old 10-24-2007, 04:31 PM
I like that a lot! You just mini tubbed it so that you wouldn't have the tires rub the lip or the inner wheel house? And are you saying after you mini tubbed you could fit even bigger tires on it, than the ones in that pic?
What sizes BTW? Just to get an idea about how big they are.
Thanks yet again
Old 10-24-2007, 04:48 PM
the wheels and tires in the pic fit without minitubbing... just not very well.
those are 18x10 w/ 5.75 inches backspacing and a 295.
since the car is now minitubbed, im going to have the rear wheels widened to 12, so i will be able to run a 315 or larger.
