Old 12-07-2007, 02:06 PM
James OLC's Avatar
Default Fitting 18x8.5s with 255/35's on the OLC '67 Camaro
The pictures aren’t great and for that I apologize but a couple of people had asked for some quick pic’s of the wheel/tire mock up that we’re doing on the ’67.
For the record the wheels in the picture are 18 x 8.5” with a 6.125” backspacing and a Toyo Proxes R888 255/35-18 tire. We are running ATS AFX “tall” spindles with AP Racing 6-piston calipers (14” rotor) and Global West upper and lower control arms. Modified stock subframe (ATS Chicane-LM coil over conversion) with Penske shocks. We’re using Baer Tracker tie rods and they are the tightest clearance issue that we have. The inner wheel wells have been tweaked slightly, but not for the tire (dry sump tank clearance, etc.).
We stared with a Tire-Mate backspacing tool but decided to buy a cheap rim from Summit to make sure on the critical clearances. We had a variety of spacer that allowed us to play with different backspacings.
We are not 100% done checking everything out – hopefully we’ll put that to bed tomorrow and I’ll post more/better pics over the weekend.
I am not going to suggest that this will work for everybody but it’s where we are at right now.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 12-07-2007, 02:37 PM
That is really beefy. How close is the tire to the frame on full lock (both F&R)? Cool rim for the price too.
Tyler
Old 12-07-2007, 03:45 PM
James OLC's Avatar
We had about a 1/4" - 3/8" at the front and probably a 3/8" -1/2" at the back. We'll play with it tommorow and I'll check some of those other clearances we talked about. Until then it's off to Van Halen!
James
1969 Camaro - Dusty
Old 12-09-2007, 05:31 PM
James OLC's Avatar
Tyler - we had a chance to play some more yesterday at ride height and at 'full' compression, going lock to lock on both sides. I'll give you a shout tomorrow with the details and email you the clearance pics that we got. Looks like no problems. Now we just have to decide on a final BS for the rear and it's hello HRE...
James
1969 Camaro - Dusty
