Old 12-20-2007, 08:58 AM
DRJDVM's '69's Avatar
Default 4L60 vs 4L85e...size??
Are the dimension for a 4L60 and a 4L85 the same ??
The reason I'm asking is I know a 4L60 will fit in my Barracuda with little/no tunnel mods....not sure about the 4L85e...
Old 03-09-2009, 11:36 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Default Average vs. HUGE and HEAVY!
Probably have to remanufacture the tunnel to get the '85E to fit.
RicG
Ric
Old 03-17-2009, 01:48 PM
Steve Chryssos's Avatar
I have Vinnie's car on a lift. If you would like me to take some 4L80E measurements, just give me a call.
________________
Steve Chryssos
Ridetech.com
Old 03-17-2009, 02:56 PM
tjbruning tjbruning is offline
Ned - we can look at your mock up trans and compare it to Rob's 4l65e when the correct bell housing arrives. One thing to keep in mind is the bellhousing's aren't interchangeable. The 4l60e has a removable 365 degree full bell. You're 4l80e to 6.1L HEMI adapter is different also (starter location).
Quicktime is working on a bellhousing. Only 3 to 4 weeks left (which is only about 9 months behind).
Old 03-17-2009, 03:43 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Ned's post is from 12/07........fyi
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 03-17-2009, 04:27 PM
doh! Bellhousing's are over rated anyway.
