Old 01-19-2008, 12:42 PM
67rstbkt 67rstbkt is offline
Question Drip rail shaving on a first gen?
Has anyone here ever shaved off the drip rails on a first gen? I'm doing up a 67 Firebird and allready started cutting off the drip rails. I'm hoping that I'm going about this the right way. Are there any pics out there? Thanks.
Old 01-19-2008, 12:54 PM
monza's Avatar
monza monza is offline
Lots of examples around best to do a search, here is a nice one...
Originally Posted by 96z28ss
If you can't find some "how to do's" or build pics on a search someone will offer some advice I'm sure.
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 01-19-2008, 01:17 PM
rjsjea's Avatar
rjsjea rjsjea is offline
Not a first gen, but did it on my Demon. I cut about 3-4" at a time then welded, grind,weld,grind,cut,weld,grind.............you get the idea, it was time consuming and was the first time doing it.
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 01-19-2008, 01:18 PM
cetchup's Avatar
cetchup cetchup is offline
Default 1st Gen. drip rails
I don't have pics. , but a quik trik I have used for a clean look is simply hammer/dolly the vertical lip over flat towards the roof. Dress smooth
with a body grinder,radius the ends nice,apply epoxy and then create/fill
entire length with a small amount of reinforced polyester filler . Use your finger to make an even radius. Paint it
Old 01-20-2008, 10:24 AM
Thumbs up Thanks
Thanks for the tips, that's the general direction I was heading with this. Does anyone else have any in progress pics on a first gen F-body?
Old 01-20-2008, 07:30 PM
KPC67's Avatar
KPC67 KPC67 is offline
https://lateral-g.net/forums/show...ght=gutterless
Here check this out.
I am in the other boat. I need a set of drip rails, does anyone know if you can buy them?
Old 01-20-2008, 08:28 PM
Smile Thanks!!
Thanks, that's awesome. I think I saw some drip rails on ebay recently, but am unsure. I believe they came up on a search under 1967 Firebird.
