Old 07-09-2005, 07:38 PM
T Bell T Bell is offline
Default Lesson learned (Zero Rust)
I recently tried out a new product on my frame to see if it works, Zero Rust. It's supposed to be similar to POR15. I'm not bashing the product (did that all day today), but I just want to let fella entusiast know of my bad experience with it. Long story short I put this stuff on about a month and a half ago & let it sit in the garage. Today I go out there and notice a rough spot like it was trying to pucker. I rub it with my thumb and lo and behold it comes off, exposing my frame's precious metal. I think I will just take it to get blasted and powedercoated. Shoulda done it the 1st time around.
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 07-10-2005, 05:16 AM
68protouring454's Avatar
Default tbell
all of those products are a joke, next time how ever you get it to metal either etch prime and urethane prime it or go ahead andf epoxy prime it to keep it from rusting.
there are no save all rust stoppers, the only one i know of is sandblasting till clean and refinishing, i live in maine so its part of daily life here
jake
Old 07-10-2005, 10:45 AM
rockdogz's Avatar
rockdogz rockdogz is offline
Default zero rust
I've been using it - on the underside of car and inner panels. I always take it down to bare metal first, and treat with picklex rust converter. I don't have any rust though, mind you - just doing this to help prevent it. Any rust found is sanded clean off or metal repaired. Seems to be holding up fine so far, 6+ months into it.
-Tom
camarorestoration.com
Old 07-10-2005, 01:12 PM
Default tom
6 months is not long enough for it to last well, are the areas going to be painted?? what happens when the stuff is painted and sealed up over?? there is a reason these type products are not in body shops
jake
Old 07-10-2005, 04:02 PM
Well mine was light rust that was taken down to metal. I used Metal Ready and then sprayed 2 coats on. If it works for you Rockdogz, more power to ya. Maybe something went wrong with mine but, I sure won't buy anymore and try it again.
Old 07-10-2005, 04:34 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Maybe Just try POR-15 next time. Worked for me. A little more expensive, yes, but a great product that works. Good Luck!
Jim
