Old 07-19-2005, 09:11 PM
Yellow67 Yellow67 is offline
Default Vortec blocks
Hi All
Can any one tell me what the horsepower limitations are on a 350 vortec 4 bolt block are.
Old 07-20-2005, 09:23 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
That's very hard to say. I'd guess around 450hp. I think rpms can be as much or more of a factory when it comes to block reliability.
Old 07-22-2005, 12:04 AM
D Rock D Rock is offline
I would think much higher, like 600 or 700 horsepower before you actually had a block failure...not to sure though.
Old 07-26-2005, 10:08 PM
I was hopping around 700 to 800. I guess well throw some boost at it and find out. Thanks for your replies.
Old 02-08-2006, 08:34 AM
427ls1 427ls1 is offline
Default block
If you can find a nice cube van block or truck 1 ton and over use that. Usually the vortec block has no provision for fuel pump, but these have been found with 4bolt main and mechanical fuel pump pushrod holes machined and everything. I have a block like this and on a scale with no main caps, it weighs 15lbs more than the standard 1/2 ton block with the same casting #'s. When sonic checked the main web is thicker and the cyl sleeves are usually .040 thicker as well.
