Old 04-20-2008, 11:00 AM
copo69 copo69 is offline
Default pro charger intake manifold
what would be the best intake manifold choice for a sbc with a d1sc pro charger . ?
if you cant smoke the tires at 60 mph your engine needs work !
Old 04-20-2008, 01:39 PM
Any single plane will work fine.
Frank Serafine
Old 04-20-2008, 06:09 PM
well i have the weiand . we already know that manifold is out . a friend just gave me an early edelbrock tm 1 the early torkmaster series it is an open plen from 2500-6500 but something keeps telling me i should spring for a victor jr or a super vic and have it blended and matched to my heads. any intake i9 use will get the blending and port matching . what ya think frank ? go with the early torker or spring for the victor. ??
how was that vacation . hope you guys had fun and got to relax.
Old 04-20-2008, 09:56 PM
Blown353 Blown353 is offline
My preference would be for a smaller single plane... a Vic. Jr. works great but the TM1 should work well too.
I have also used an RPM Air-Gap dual plane with my old blowthrough setup; off-boost manners especially at low RPM were a little better than a Vic. Jr. and mixture distribution at WOT was still pretty good with the dual plane but not as good as with the Victor Jr.
A super vic is WAY too big for a SBC that sees any street duty. I daily drove my car with a Super Vic for a while and it sucked. No mixture velocity and no power down low, and from putting around town it had poor mixture distribution and needed way hotter plugs in the 4 corners. It will work fine under boost but off-boost it's just too much intake and performance and driveability will really suffer.
1969 Chevelle
Old 04-20-2008, 10:57 PM
I am with 353, a Victor Jr is perfect in most cases.
Frank Serafine
Old 04-21-2008, 04:15 PM
thanks frank and 353 vic jr it is then. checked out your web site 353 nice ride. the bracket you fashioned off of the header tube to the pro charger bracket should i figure into one of them myself . and id like a lil more information on your belt tensor the spring pressureized one. is it something i can order or would i have to send in my bracket for it.
