Old 06-26-2008, 06:27 AM
Moose Moose is offline
Default Gear ratio for ls1 6 speed, whats everyone using
I Have 3.73 in my 10 bolt and I know that I'm going to update to a 12 bolt or a 9 inch eventually. I've always had 4.11 or 4.30's in my 4th gen.
My plans for the car are to run mid 11's on 17" drag radial, and still have the driviablity to go on the power tour.
Old 06-26-2008, 06:33 AM
68protouring454's Avatar
most of the 4th gen guys like 4.10, if unsure go 9 inch as its a whole lot easier to set up a differential then a 12 bolt, cheaper too as you can find so many 3rd members used.
Jake's Rod Shop
Old 06-26-2008, 08:33 AM
oh yeah should have clarified that this is going in my 1st gen camaro.
Old 06-26-2008, 08:40 AM
murtah's Avatar
murtah murtah is offline
3.89 I will probably go to a 4.10 once my current pumpkin wears out. I got a great deal on a take out so the aluminum case, 4.10 tru trac will have to wait. Especially at 1900!
1st on a ls/T56 is 2.66, late model Fbodies responded real well to 4.11s.
Old 06-26-2008, 09:11 AM
i have 3.89 also, however 4th gen camaro or first gen, really no different, 4.10s go best for all around performance, especially drag racing
Jake's Rod Shop
Old 06-26-2008, 03:55 PM
1969x11's Avatar
1969x11 1969x11 is offline
I'm runnin a 4.11 in mine with a 9''. It has pretty good mileage on the interstate with the t-56, I would'nt go any less than 3.90 , but I'm running a 275/35/20. Ifr your going with a 26'' tall tire, I would'nt go less than 4.11's, that is if your gonna drive it.
