Old 06-27-2008, 09:28 AM
Jr's Avatar
Jr Jr is offline
Default 350 break in question
Hi guys,
I just put in a new 4 bolt main 350ci motor in the truck. So far...I have really high oil pressure. How should I break it in?
David
Old 06-27-2008, 09:38 AM
chevyIIpost's Avatar
chevyIIpost chevyIIpost is offline
What is your oil preasure? What type of cam shaft, flat or roller? Crate engine or fresh rebuild? If it is a crate motor call the supplier and do as they say. Where is your oil preasure gauge attched to the engine and have you verified the accuracy of the gauge?
Ted Rea
"Don't drive FASTER than your guardian angel can fly"
Old 06-27-2008, 10:09 AM
Jr's Avatar
Jr Jr is offline
The motor is a fresh rebuild, I guess. I got the long block from chevy. The oil pressure needle is 3-4mm from the H. I will find out more information...My bad for not having the information
Old 06-27-2008, 05:53 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Did you put a hi-volume Oil pump in the motor?
Jim
Old 06-27-2008, 06:01 PM
camcojb camcojb is online now
first thing, get a mechanical gauge that reads in true psi, and see where you are. There may not even be an issue, but with any oil pressure delima I always start by verifying with another gauge. Since you're using one that doesn't even read psi, you definitely need to start there.
Old 06-30-2008, 01:56 PM
Jr's Avatar
Jr Jr is offline
I will get a mechanical gauge on it.
Old 06-30-2008, 01:55 PM
Jr's Avatar
Jr Jr is offline
I don't think so.
