Old 07-14-2008, 06:24 PM
Blown90 Z Blown90 Z is offline
Default accel dfi thruster
i just bought the accel dfi thruster kit with wide band and was wondering is this an easy install or would you recommend to have someone install it for me? it is going on my 90 camaro.
1969 Camaro z28: LSX 376 F1Aprocharger, Art Morrison sub frame.
Old 07-15-2008, 04:47 AM
ohcbird's Avatar
ohcbird ohcbird is offline
That completely depends on your comfort level while working with wiring & tuning. If you have a stock TPI, etc; it's easy. What's your combo like?
PM me if you need any help- I believe you'll like the thruster; it's a great way to get a very tuneable EFI setup.
JEFF
Old 07-15-2008, 09:42 AM
i have the superram but same thing as the tpi, see sig for details. i will pm if i need help though. thanks
Old 11-12-2008, 12:13 PM
ss9t7camaro ss9t7camaro is offline
Default accel truster
hey hows it going i have an accel thruster dfi that i just bought and i was wondering what distributor did you use or can you use i have an msd dual sync but im not sure if its compatable i will apreciate any info
Old 11-13-2008, 09:24 AM
sacarguy sacarguy is offline
Default yes it will with proper setup
accell will tell you no ... most the accel dealers will tell you no
THEY ARE FULL OF CRAP
its a magnetic pickup for the crank sensor .. and a single magnetic pulse for cam you will only need to add a adjustable phasable cam rotor.
its as simple as that you set up the thruster in crank plus cam sync mode .. and then set up everything corespondingly ..
dont think of it as a distributor think of it as a crank triger and a magnetic cam sync.
Old 11-16-2008, 04:34 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Just my .02
I am installing a Gen VII Thruster with dual synch, wide band...and a host of goodies like a/c clutch, fan, and TCC control to the system. All of this on a modified Pontiac 400 in a 76 trans am. I'll be doing a full write up for Pontiac Enthusiast magazine.
I decided to edit my comments at this point as I don't want to appear to have passed judgement on the system BEFORE I have it installed and running.
There were no printed instructions with the set and there have been some changes since the instructions were posted to the download site. That has given me some trouble...but we are working through that now.
Last edited by 69MyWay; 11-17-2008 at 04:50 PM. Reason: Decided to wait until install complete to pass judgement.
