Old 07-19-2008, 09:00 AM
viper11 viper11 is offline
Default what went wrong?
hi
I just got my charger running again with its new forged 440 twin turbo, (have a couple header gasket leaks to sort)
I have the ms1 v3 extra 29y4, I was tuning the car in my driveway in park with no load using autotune at different rpms to get my ballparks again (it was running last year and my msq is pretty close ) brought it upto about 4000rpm and the autotune was doing a good job of smoothing everything out and all of a sudden it started misfiring on one cylinder (completely dead) as i reduced the rpm it slowly caused it to stall
I tried to restart it to see if it would clear up but it wouldn't quite start, after cranking and cranking there was a huge backfire that was extremely loud
I let the car sit for a few minutes and tried again but I could barely get it started and keep it running. its misfiring, popping and clattering. I had a hell off a time getting it up the driveway into my shop, it sounds awful, not to metallic, but not all exhaust leak either.
it takes 20-30 seconds of turning over the get it to start and i can only keep it running for 2-3 seconds, all the header pipes feel warm indicating fuel and spark
where should I look for answers? it went from 1 dead cylinder to not running at all, what could cause this???
I will do a compression test first then pull the valve covers witch takes 3 hrs cause of all the piping
thanks for anyones input (I know this might not be the ms but someone may have an idea)
I will be testing the ms with my stim too
jason
Old 07-19-2008, 09:11 AM
Originally Posted by viper11 View Post
I have the ms1 v3 extra 29y4.
what system is this? If it's not a mechanical issue then it's in the computer programming/wiring. I have never heard of the above system. Is it laptop programmable or self-tuning?
What is this................... maybe again in English?
Too many abbreviations.................. I thought I knew efi lingo but you've got me so lost...........
Old 07-19-2008, 11:18 AM
sorry megasquirt v3 extra is the model and 29y4 is the build code
stim is the stimulator to duplicate the motor
jason
Old 07-19-2008, 01:09 PM
jason
I've used several different efi systems, but not that one. It sounds like a mechanical issue, unless the tuning software "self-tuned" itself completely incorrectly. Not a big fan of self-tuning, prefer to make the changes myself through datalogging.
Will this software let you tune? Does it have a a dash feature that shows you what your timing, pulse-width, a/f, etc. is while it's running?
Old 07-19-2008, 01:22 PM
hi
this is completely programmable by laptop with everything displayed and adjustable
my tune is very close but the autotune tweaks the fuel tables to match my preset a/f targets it is restricted to 5-10% max
everthing was going good then all of a sudden one cylinder went dead like a dead plug now I can't even start it
jason
Old 07-19-2008, 01:57 PM
adynes adynes is offline
I have the same computer on my car. I'm using 36# Bosch design III injectors, and I think they need a cleaning. The base tune was way too rich while trying to fire the engine for the first time, and the plugs fouled. The engine sounded much like the symptoms you describe. After changing the plugs and getting the fuel within range, it ran fine. Then, after adding spark control, I had similar problems, but I think this time the problem is a noisy tach signal, because when I disabled spark control (defaults to the base setting) it cleared up. I haven't messed with it since do to other work being done (paint, turbos, etc).
Have you checked the plugs yet? If that's not it, maybe check your ignition signal wiring for problems, or maybe the computer ground. Good luck.
