Old 10-15-2008, 02:22 PM
stssilverado stssilverado is offline
Default Axle not centered in car
My 68 convertible camaro's axle isn't centered. It's a mono leaf car and I noticed the axle is about 1" off center. Therefore my new wheels/tires rub the lip on the passenger side only. If it were centered, there wiould be no rubbing.
How does this happen and how do I fix it? I already put new poly bushings in the leafs/shackles. Is there an adjustment point/area?
Old 10-15-2008, 04:52 PM
WILWAXU WILWAXU is offline
VERY common. My Nova is .5" off to the passengers side.
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 10-15-2008, 06:43 PM
ok, so.....how do you fix it??
Old 10-17-2008, 03:51 PM
Swain's Avatar
Swain Swain is offline
Easy way is to run different back space on each wheel. Pull the wheel that rubs in. We do it all the time.
Old 10-18-2008, 05:20 AM
easy way? that involves buying another custom wheel. i was hoping for an answer like, there's an adjusting point on one of the leaf spring mounts. can it not be fixed?
Old 10-18-2008, 06:38 AM
dhutton dhutton is offline
I think the "easy" way is to move the spring perches on the rearend. Not sure that is the "right way".
