Old 11-19-2008, 03:05 AM
Default driveshaft selection
I searched and was surprised there was not more talk of this anywhere that I could see. Maybe it's a no brainer and I shouldn't be asking!
Anyway, it seems like I see a lot of guys with less power than me using a 3.5" aluminum driveshaft from Inland or Denny's. Is there a certain level you really should go from steel to aluminum? I have the steel driveshaft that came with my TKO 600 from Keisler. Is there any reason why it's not a good idea to use it? I believe it's a 3". Will fitment issues come into play with 3" exhaust?
Quick specs of my car:
procharged 406 approx 650-700 rwhp
TKO 600
9" rear 3.70 gears
3" exhaust with x-pipe will be run
thanks
Old 11-19-2008, 07:32 AM
Pretty sure it's around 600hp you need to go to a 3.5" aluminum. That's what I have, and got it through classic chevy and inland. They recommended it for my application. My exhaust is tucked way up and have no issues with exhaust contacting anything. They did modify it some. All you will need is some stainless 3" pipe and a good welder. A call to Jim at Classic Chevy is a good idea. He is extremely sharp. I like to be well within the rating of all my parts...especially a drive shaft. Reliability is important.
Old 11-19-2008, 08:14 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
I bought my last driveshaft from Denny's. Call them. They'll steer you in the right direction and not oversell.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 11-19-2008, 03:16 PM
Thanks guys. I will check out both Inland and Denny's.
Old 11-20-2008, 10:50 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Im going to run a carbon fiber shaft from PST.
A little more expensive but there tested and guarnteed for high HP applications and they use them in pro stock as well.
http://www.pstds.com/critical_link_drive_shafts.htm
Rich
67 RS/SS
Old 11-20-2008, 10:55 AM
parsonsj parsonsj is offline
Mark Williams 3" 4130 for me.
Nice stuff.
jp
John Parsons
